Karoq 2.0 TDi 2019 - has developed a tic. Mechanic is just throwing my money at it with no effect
Hey all.
So this started with my wife, this is her car used for a daily 30m commute and weekend travels to see family (2 to 3 hours, sometimes the odd 200 mile drive down the A1/M1) car has been flawless for years. Every day things like tyres, brakes etc, every service hit, no MOT issues. Until August.
In August, randomly, the car would just stutter/misfire. No codes on the dash, nothing in OBD, it would just randomly once on her 30 min journey lurch and then pick up as if nothing had happened. I originally thought it was just a wrong gear for the pull out on the roundabout issue (A174, stop start for 10 miles then a series of slip roads and roundabouts) - booked it in at a VW specialist, they replaced the battery and coded it in, sent us on our way.
2 weeks later, a series of the same stutter, 5 or 6 in a row, with maybe 3 mins between each, dashboard lit up with hold assist fail, traction control fail, parking sensor fail, glowplug light, engine management light. She was stuck in traffic having a panic, engine in limp mode. I told her to not abandon it at the side of the dual carriageway but leave at the exit 2 miles up or into the parking area just after if she couldn't get into the lane in time. She killed the engine (which was holding revs at 10,000) and sat. I drove over with the van (which she won't drive because it's too big) got in, started the engine. All is forgiven, no lights, no limp, no stutter.
Back to the specialist - reads the codes, crankshaft sensor he says, replaces with OEM, sends us on our way. 2 days later same again.
Back to the specialist - reads the codes, still crankshaft sensor... must be the loom. I'll make a bypass cable. He did that. 3 weeks with no issues, then the symptoms returned.
Back to the specialist - I said, "if that cable was knackered, what's the chances that other cables in the loom are also knackered?". Quite possibly, but it's a bitch of a loom to access, codes say camshaft sensor, lets replace that. Oh and while I'm here I'll take out your air care sensor - they're known to make the signals dirty.
Now we're 2 weeks on from that and its doing it again. The loom apparently wraps under the gearbox, is incredibly difficult to get to and will take 20 hours labour at least, so I've said I'll find another mechanic to look at it. However, has anyone experienced this before I start my phone calls to the auto electricians in the area? It might not be the loom, given replacing the crankshaft wiring didn't fix it (he ran a separate wire bundle to the ecu). I can get codes etc from the car, he sent me everything that VCDS recorded.
Edited by Doofah
Car Model in title
  • Doofah changed the title to Karoq 2.0 TDi 2019 - has developed a tic. Mechanic is just throwing my money at it with no effect
Couple of thoughts, and I'm not a mechanic. I had the 2.0 TDI 140 bhp engine in my 2013 Touran, so was on the VW Forum. It might be worth asking the same question in the engine section of that forum, there is a very knowledgeable and helpful guy on there who runs an independent VW garage. The other thought was fuel supply; so fuel filters, fuel pumps, does this happen when the fuel level is low in the tank, is the tank cap breather blocked, could there be water contamination from condensation forming in the fuel tank?
I originally thought fuel issues - because it started 3 days after the local garage had it's diesel pumps shutdown due to a malfunction and my wife had filled there the same day. We had it to a different mechanic who drained the tank and checked the fuel pump and filter and said all looked good. She did have a habit of running it to the middle of the red then filling to full so blocked filter/pump came to mind too - but nothing on VCDS for fuel rail pressure issues etc so we put that down as a dead end (I did however already buy a pump to empty the tank again via under the seat so I can see for myself) - and it will do it equally at a full tank as much as a half full, so possibly not - though that doesn't rule out breathers etc.
Rarely does it on the first journey of the day, generally does on the second journey or return leg if it is going to do it - so cap breather could be a good call there, I'll go check that first thing in the morning.
I'll have a look into the VW forum too thank you!
