Battery restricted use issue
Does anyone else have a restricted battery warning on the dashboard after four attempts at replacing batteries it still happens this looks like a perennial issue by Skoda who are denying or responsibility. please let me know if others have this
If you have start stop the new battery needs coding in.
Coding alone may not be enough. The fitted battery has to match the coded type and capacity, AGM or EFB. Worth reading the adaptation values with VCDS or OBDeleven and comparing them against the battery in the car.
Is this the key battery or the car's 12V battery?
If the key battery, when removing the old one, press a key button to reset it; then install the new battery and away you go.
Recently Browsing 2
