1998 GLi engine flat spots :(
the sparks you put in did they have three tip instead of one tip on the top of the plug ???? if not then you need to muliti-tipped spark plugs, this point raised is a good one due to the fact my parents had single tipped in thiers and it was acting quite wierd..... a good point indeed :D
Q
interesting you shoudl say that because the ones i took out were single tipped and i bought 2 sets of plugs by mistake i had 2 multi tipped and 4 normal tipped and just put single tipped ones in! maybe I will try buying 2 more multi tipped ones and see what happens? what do u mean when you say your parents car was doing funny things?
cheers
Ant
well my felicia gets better and better,
just spent all day with dad trying to change the timing chain (my god am I glad I did!!!! All the teeth on the sprockets had been 'torn off' Ie it was almost a bare wheel with no teeth!And the timing chain itself was unbelievably loose! Unfortuanately the small sprocket was too small to fit over the shaft :( So anybody with a rattly felicia may wanna give their timing chain a good check over (WARNING ITS A PIG OF A JOB) we ended up having to drop the engine to get the timing chain cover and cam wheel off :(
