Jabba ARB & Eibach springs
They are being fitted very shortly and as expected, i'm a little excited to the eventual outcome of the handling and will it really be so much different ?
Many thanks to VRStu (Stu) for all his help with the ARB :rolleyes: Top bloke.
It will be very different indeed.
No more understeer courstesy of the Jabba ARB, which is controllable using the throttle mid-corner.
Aggressive into a corner (or roundabout) with a sharp lift off will introduce some oversteer, especially in the wet. When the back goes it does so predictably and completely controllable. :D
The eibachs will stiffen things up, reduce body roll and dramatically improve the looks of the car (no more rollerskate effect). Ride quality I feel isn't really effected.
I'm sure more people will be able to add more comments than me on the awesome-ness of the Jabba ARB, which gets a definate :thumbup: from me.
I used the Jabba ARB and Eibach springs to great effect on the recent "Ring" trip
Either I am a Grandad driver or you guys are rally drivers in your Vrs's ? :rofl:
Lift off oversteer, catching the drift in mid corner, in the wet !! Around roundabouts, I'm geting too old methinks. :)
You'll notice the difference even if you drive normally ;) Will corner a lot more flatly and feel much more balanced.... :D
Chris
Chris
Phew, cheers Chris, happy to see I fall into the 'normal' category. :) Thanks for all your advice guys.
What shock absorbers do you guys tend to use with these lowering springs?
thanks.
I'm using the standard shocks , but others are using the Eibach proshocks with the springs
What sort of price are we looking at for ARB and springs and fitting?
New?
ARB = £210 I believe
springs = £130 odd
dampers = £300 odd (I can't remember what I paid so long ago :o)
Labour for ALL the above, around 4 hours I think (front struts are a pain)
Fronts are only a pain if you don't have the "opening" tool. If you do, they're a piece of cake :D:rofl:
Chris
Fronts are only a pain if you don't have the "opening" tool. If you do' date=' they're a piece of cake :D:rofl:
Chris[/quote']
its not so much the opening tool (i used a short chisel) but the spring compressors because you need to compress the spring/shocker assembly to remove it from the hub , then use them again to dismantle the assembly
Well, if only the fronts were as easy as the back. :rofl:
