Brake upgrade this weekend
How about fitting S3/TT Quattro rear brakes or RS4 brakes? Anyone done so? I have a 4x4 also and going for the 312mm front setup also. The only problem is whether the hand brake cable fits, as otherwise the quattro rear setup is identical to Skoda/VW one. Does the vRS have larger spare wheel as the 15" which comes as standard won't fit over the 312mm discs. Of course one can swap a wheel from rear in case of front wheel damage, but it's more than little impractical...
The vRS has a full size (17") spare. :o)
You'd be better off spending the extra cash on even better front brakes than doing the rears as well. Its all about the fronts you know!
15" which comes as standard[/i'] won't fit over the 312mm discs....
Mine's running 16" as standard !!!!!!. Have you a rouge one ??????
Point noted mate :thumbup:
Mine's running 16" as standard !!!!!!. Have you a rouge one [i']??????[/i]
Why would he have a red (Rouge):mad: one, do you want colour brought back to those white cheeks of yours??:P :P :P
It's time for you Horlicks mate ,,,,,,,,,,,,,,,, :finger:
