Sources of diagnostic hardware, software and advice - including VCDS
Ross-Tech - the source of VAG-COM software.
Ross-Tech: Home
Ross-Tech - 1.8T Vag-COM Info - although primarily for the US spec 1.8T, the cruise control activation code is correct for the UK spec Octavia
Ross-Tech: VAG-COM: 1.8T VAG-COM Info*
VAG-COM FAQs - direct from Ross-Tech
Ross-Tech: VAG-COM: FAQ
VAG-COM Discussion Forum - An information exchange for users of the VAG-COM diagnostic package for VW/Audi/SEAT/Skoda. Moderated by Ross-Tech. Open to anyone, but the topic is strictly VW/Audi/SEAT/Skoda computer diagnostics.
VAG-COM : VW/Audi Computer Diagnostics
ilexa onboard diagnostics - for VAG-COM as well as OBD1, OBD2 and EOBD systems
ilexa_onboard diagnostics
ilexa onboard diagnostics website forum - Diagnostic tools - VAG-COM discussion - as it says on the box.
VAG-COM diagnostic tool technical support
OBDTool.com - OBDTool enables owners to diagnose and troubleshoot problems in any system in a car that has an on-board computer.
OBDTool.com
B&B Electronics Ltd - a source of components for VAG-COM leads.
RS232, RS422, RS485, Industrial Ethernet, USB, Serial Converters, Serial Isolators, Wireless Communication Solutions
ARlab - Vag-Check for PocketPC - Vag-Check is a diagnostic scan tool application for VW, Audi, Seat and Skoda running on PocketPC platform.
ARlab Devoted to Pocket PC
VWvortex Forums - VAG-COM Diagnostic Forum - sponsored by Ross-Tech
VWvortex Forums: VAG-COM Diagnostic Forum
VW Diagnostic Trouble Codes - DTC Table - a comprehensive table of DTC codes for the VW courtesy of Bentley Publishers. Very using for decoding ECU error codes
VW Online Technical Library - Diagnostic Trouble Codes (DTC) Tables
Gendan Automotive Products - UK suppliers of diagnostic tools, inclusing official Ross-Tech interface cables - for the VAG range.
Volkswagen (VW), Audi, Seat and Skoda Car Diagnostics :: Gendan Automotive Products
Volkswagen/Audi "Standardized" Measuring Block Groups for Gasoline Engines
A list published by Ross-Tech of VW/Audi "standardised" measuring blocks for petrol engines
VAG-COM - Air Mass Meter problem diagnosis
Advice on using VAG-COM to diagnose MAF problems - TTOC
Entire Diagnostic Code (DTC) List For All Vehicles
AutomotiveArena.com complete list of DTcs for all vehicles
OpenOBD.org - Locations of VAG vehicle diagnostic sockets
en.openobd.org - locations
Please post details of any other useful links in ths forum and I will then add them to this master list.
  • ColinD unpinned this topic
Guest
