where has my vrs clutch gone
hi i picked up my vrs o2 from the garage yesterday and on my first journey after about 100 miles it started becomeing difficult to change gear the when i ggot to a roundabout it would not go into gear at all so i turned it off then i could put it into first and pulled over the clutch peddle was on the floor bottomed out at this point i then called the aa by the time they got there about 20 minutes the clutch was back in the normal position with normal pressure . skoda dealership have now been trying to make the fault occur again which it will not reading other threads people have talked about the clutch selctor arm on the gearbox cracking any body got any idea
:mad: cheers
Hi
I think it could be the master cylinder.
It is a common fault on this car.
If it is it could a while for this to happen again.
Sarah
skoda have not got a clue what to do about but have agreed to change the master cylinder is there a new type of master cylinder that does not have this fault or is it just luck:mad:
Hi
Yes I do believe it to be a superceeded part
Sarah
Had exactly the same problem on my O3 Octavia Vrs. Garage changed the master cylinder. I have had no problems since.:thumbup:
What is involved in changing this? Big job or DIY? Rough cost...?
Just curious! :)
Not to big a job, the pedal and its box come out as one part. Held in by three bolts. Getting to the pipes in the engine bay can be tricky depending on engine type.
