Skoda Fabia Break Switch Replacement
I have a Skoda Fabia Classic 1.4
and can't get to the break light switch because of the penalling
could some one tell me how to get to it ?
Many thanks:confused:
Many thanks for the info..Much Appreciated, I managed to fix it myself in the end.
I didnt have to remove to much of the paneling..it is sectioned and if you look hard enough you will locate the relevant screws you need to unscrew. My tip..
go to the fuse box there's a screw there, unscrew that and then its just a matter
of unscrewing the ones in the footwell area.. You need a torch..A star shaped screw bit. Once you've unscrewed, lightly tug at the panaling until you can see the breakswitch from behind the panaling and then you can get at it from there..
I hope this is of help..Once Again many thanks
Glad you got it sorted.
Had you thought about joining Freedom which helps to maintain this website and it resource of useful information?
No! I must admit, I hadn't but I may well do as time goes on....It's nice to know there is a resource to go to when you need to...it's a great site...
