rear wiper leaking from strange place?
tried to use the rear wiper washer today but nothing came out, opened the boot and there was a puddle on the black boot trim so i took of the plastic panel on the boot and tried it again. the water is leaking from the black connector that the water pipe attaches too. the pipe is connected but on the black connector there is 2 holes (which are meant to be there) and the water is coming out of them, what are these 2 holes for? anybody got any ideas what could be the problem?
i know these problems have been on here before but i done a search and found nothing the same as this problem.
Is the jet blocked?
Do you use OEM screenwash?
no i dont use oem screen wash do you reckon thats the problem, how do i unblock it then?
in fig 5 that black connector is similar to what is on the fabia but it has 2 holes on which is the problem i think it must be blocked and is forcing the water out of these 2 holes
ive had a bit of a fiddle with it and there is loads of crap in the rear washer a little bit of water came out but its still leaking into the car.
