Aero wipers - update
now that i have them fitted up front i quite fancy them for the rear, do they do them for the back? mines an estate btw :)
Don't think they do, certainly not found anything for the hatch as yet bengie. IIRC the estate has the wash seperate to the arm unlike the hatch, so you might be able to just use one from a golf or smilar which is the correct size. The wash is the problem for the hatch.
HTH
Having had mine on for a few days... they are great :-) Yep... my rear wiper needs replacing too......
There is a better standard hatch one that is on later models, does anyone know if this has the washer built in as well? May just be a straight swap (yeah right!)
Should do if that is the plastic shrowded one.
However if anyone has a part number for this that would be great :)
the A3 has the washer as part of the wiper base, is that any good to you guys with the hatch?
Don't know bengie, the thing is that the golf one has it built into the nut area, whereas the Octy has a pipe that is built into the arm and follows the wiper.
Don't think the A3 one is any use IIRC, but i think the A6 looked more promising.
