Fitting an MFD2 into a fabia!!!
Hi guys,
Ive purchased a VW MFD2 sat nav unit to install into my fabia...............Ive bought all the relevant connectors and everything and wired it up myself (because they arent really compatible with each other), and it works but there is a input on the mfd2 that is called "safety" i havent got a clue whats its for, so i just left it and as the system loaded up and i entered the pin it then said "safety unplugged"...........If any one has any experience with this kind of stuff and can think what it is, id be VERY grateful for any info?? :)
Jimbo
I think its connected with the GALA system but not sure.
I would say it might be the constant 12v supply which keeps the system out of 'safe' mode.
Is it not the wire that's connected to the handbrake switch, so you can't watch movies whilst driving along. Most people wire it up permanently in the "handbrake on" state to remove the safety restriction.
  • 5 months later...
MFD or MFD2?
If this is the MFD2 in a fabia can we have some pics/instructions please?
  • 3 months later...
Any pics yet?
Can anyone confirm that a MFD2 unit will fit into my Fabia vRS SE (I asume I will lose the small cubby hole under the Symphony head unit) ? Is it just a plug and play or will some bodging be required ?
It most certainly isn't plug and play and a large amount of bodging would be required.
Hi Stu ('the wise one') thanks for the reply. Do you know if it physicaly fits into the dash without any cutting?
I don't know the dimensions of the MFD2 nor the Symphony but I wouldn't think so.
It is:-
220mm wide at the top
130mm high
212mm wide at the bottom.
Good luck.
Are those the dims of the MFD2 or the Symphony?
MFD2. You can tell by the taper.
An MFD2 could fit into the Furby Vrs! For those interested, the MAX dims for Fabia vRS SE are; W 220 x H 133. To obtain this size would involve a) remove cup holder slot on L side and B) somehow removing part of dash under the slot on the R side.
Well I gone and done it now! Bought a Audi Navi Plus unit off of EBAY and am gonna attempt to squeeze it into my Furby vRS SE over the coming weeks (I am virgin in these type of things!) It could take months and hundreds of posts on here to get it done. Wish me well, will post details if succesful, or will hide, if not!
  • 3 months later...
Did you get this to work in the end?
MFD2 units from T5, Touareg and Touran had square edges and double DIN size, I know people on the net succeeded fitting them into old Passats and such so so technically they should fit into Fabia and Octavia mk1 as well. MFD2 require CAN-BUS, rather than GALA to operate properly (otherwise sat nav position doesn't update properly, light dimmers don't work and the radio switches itself off once an hour), but I know there are CAN-BUS adaptors which simulate signal for MFD2 on sale in Germany. Unfortunately the information is scarce and in German, so someone with knowledge of foreign language would have to start digging on .de forums and shops to see if those adaptors work properly in GALA cars...
Case and point - Frenchmen fitted MFD2 to old mk4 Golf, it's just that je ne parle pas francais to read how...:
