Windscreen Wiper Washer
Hi,
My fabia appears to be missing an insert in the passenger side windscreen washer jet (the insert has a small hole to direct the water), the water gushes out rather than sprays. Any ideas how I remove the washer to see if the part is loose or has completely gone?
Thanks,
Simon.
sounds like you will require a new jet
Really? It looks as if it's just a piece of plastic that's missing. I'll have to visit the dealers the.
If it's coming out as a gush of water, then the fan spray is missing - when they block they pop out.
Replacements are only a couple of quid, but your dealer might not have them in stock - search on here for the part numbers.
They just push straight in.
Cheers Joff that sounds exactly like the thing I need!
