Brake Caliper Painting
Whats the best way to get this done?
Put them to a body shop and let them or do it myself?
if its easy enough to do what kind of paint would you reccommend?
spray or brush on?
any high temp paint be ok?
cheers
Scott
If they're still on the car, brush on some smooth finish Hammerite. Only takes a few hours.
When I got my TT calipers, I sprayed them with a few coats of smooth finish Hammerite before fitting them. Came up good.
Well, you could always get it done at a garage, but the satisfaction of doing it yourself would be better.
Give them a rub down, and some Metal primer. Hang them from the ceiling of your garage or another ideal place. The spray them using a Hammerite can.
Will work a treat...
