Heater Control Illumination
Hi, my heater controls on my 2001 Octavia do not light up when the lights are on. Does any one know if this is an easy repair, bulb blown ? How do you gain accesss to it, I'm not that bothered about it, so if it is hard to do or very time consuming I will leave it as it is.
happened to me pull the middle **** off its really stiff but will come off i used pliers with cardboard so not to mark the ****! theres a small bulb behind it get a drinking straw place it over the bulb and pull change the bulb and it should work!!
fiddly but well worth doing :)
Thanks, I will try that and see if I can do it.
as said before it is fiddly but not 2hard hope you get it sorted :)
