subframe bolts
hi all quick question, when replacing the clutch and flywheel does the subframe need to be removed, or the bolts loosened, i have had the clutch and flywheel replaced last month and had to take car to a garage today to have the subframe bolts tightened as it was making an blood-curdling noise and want to know if the other garage should pay for the labour charge i have just recieved...ie he never tightened them properly to start with!
Dan
the bolts on the alloy carriers ,that the wishbones mount to ,require replacement when they are loosened
