still leaking aaaaaaaaaagh
removed my rear door carriers and resealed with vw seal strip as per lummoxs guide,but I've still got water creeping over my rear passenger sill.any advice on fixes much appreciated
Perhaps you should have invested your £12 after all.
Good luck with the fix.
Did you remember the seals that go in between the door trim clips and the carrier?
They are quite easily lost.
found mine are leaking today - both sides.... is this a common prob?
i was wondering why i had condersation every morning!
Very common unfortunatly, but can be fixed easily if you have a search around on here. Mine went within 2 weeks of getting the car (used) but the dealer knew exactly what was wrong even before I explained fully. Not sure if they re sealed it or changed the part but to be honest, I dont really car - its still nice and dry almost 6 month later! :D
cheers stu very helpfull
traced fault to a grommet ,on the door rod it has an extended rubber boot on it which had gone back on itself,pulled it forward tiny ziptie on the end.:) job done
