Help with o2 sensor / oxygen sensor fault codes
On a Polo 1.4 16v 75bhp
2 Faults Found:
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1: Electrical Malfunction
P1196 - 35-00 - -
17591 - Shareware Version. To Decode all DTCs
P1183 - 35-10 - Please Register/Activate - Intermittent
The second one is translated into "Linear O2 Sensor / Reference Voltage Short to B+"
A previous 17604 has been cleared, only to reappear 7 days later with the 17591 as well.
So any ideas how to sort the potential cause of these?
What does a short to B+ mean?
Adam
"What does a short to B+ mean?"
Short circuit of the affected circuit to another wire live at battery positive voltage.
Usually caused by damaged wiring, however the fault could be inside the O2 sensor itself.
Thanks Chris, I thought as much. Its an intermitted fault going by the codes - happens every so often :(
Decided to get it replaced - pricey though - £220 supplied and fitted at VW dealer.
Best price online £99.99 delivered from Lambdapower .
Can anyone confirm the oxygen sensor configuration on a 1.4 16v (2002) (engine code bby) - all the online sources I can find show it as a 5-wire, pre cat sensor, but they show nothing for post cat. Is there a post cat sensor? Anyone have any experience of this on similar fabias or polos?
Okay, the plot thickens! (long post)
As the pound is so strong against the dollar I'm now proud to have a registered and activated vag com installation!!!
I ran an autoscan on it tonight - just for fun and found an extra three fault codes :eek:
3 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
30-10 - Open or Short to B+ - Intermittent
29-10 - Short to Ground - Intermittent
28-10 - Short to B+ - Intermittent
Previously I got these ones;
2 Faults Found:
P1196 - 35-00 - -
The 17591 being Linear O2 Sensor / Reference Voltage Short to B+"
Now to me this seems a bit odd - different components complaining about electrical shorts.
Checked the voltage with engine stopped (though vag-com) - 11.80v
and again with engine running - 14.5ish v (I think)
Does that seem about right? 11.80v seems a bit low to me, and over 14 quite high.
Low and behold, sitting with the engine idling it all went a bit rough (like it wanted to stall) and the CEL came on again.
giving;
P1196 - 35-10 - - - Intermittent
Readiness: 0000 0000
So, is there any consensus on what to do next? I realise that this heater circuit on the o2 sensor is to do with keeping it hot when the car is cold - I think thats when all of the CEL have appeared - when engine not up to temperature and idling in traffic.
Does it sound like it would be worth replacing the sensor (@ approx
I think your battery voltage readings are OK.
I'm fairly sure that there is a measuring block that enables you to read the O2 sensor heating current.
I'm sure if you post the engine code and the full text of the auto scan (including the Module ID's etc.) Sebastian will be able to help you.
You could also try posting here:
VAG-COM diagnostic tool technical support
Thanks Chris
Engine code is BBY
A few logs (first one just a copy of the initial fault codes, not a full autoscan);
Monday, 04 December 2006, 18:04:41
VAG-COM Version: Release 409.1-US
Control Module Part Number: 036 906 034 DD
Component and/or Version: MARELLI 4MV 4963
Software Coding: 00071
Work Shop Code: WSC 00566
2 Faults Found:
P1196 - 35-00 - -
FIRST AUTOSCAN;
Chassis Type: 9N - VW Polo
Scan: 01,02,03,08,09,15,17,19,37,44,45,46,55,56,69
Address 01: Engine
Controller: 036 906 034 DD
Component: MARELLI 4MV 4963
Coding: 00071
Shop #: WSC 00566
No fault code found.
Address 03: ABS Brakes
Controller: 6Q0 907 379 E
Component: ABS FRONT MK60 0103
Coding: 0001097
Shop #: WSC 00788
Address 08: Auto HVAC
Controller: 6Q0 820 045
Component: Klimaanlage X0840
3 Faults Found:
Address 09: Cent. Elect.
Controller: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 25742
Shop #: WSC 00788
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 6Q0 920 900 X
Component: KOMBI+WEGFAHRSP VDO V18
Coding: 01441
Shop #: WSC 00566
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 1S31
Coding: 00014
Shop #: WSC 00788
Address 44: Steering Assist
Controller: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00140
Shop #: WSC 00788
Address 45: Inter. Monitor
Controller: 6Q0 951 171
Component: Innenraumueberw. 0018
Address 46: Central Conv.
Controller: 6Q0 959 433 E
Component: 28 Komfortger
Check the Oxygen (Lambda) Sensor Heater circuit.
Disconnect the sensor and measure the heater element's resistance.
Start the engine and check for voltage going to pins that would connect to the heater..
-Uwe-
-Uwe-
Thanks.....guess i'll have to locate the sensor then, and follow the cable :)
Any idea which wires/pins to probe. This is i believe a 5-wire sensor, so I have been looking at this; Lambda Sensors diagnostic advice fault finding and symptoms
Which seems to suggest its not easy to test wideband sensors.
If it helps this is the connector diagram from LambdaPower
So when I probe the heater circuit, what resistance am I looking for?
And for the voltage with the o2 sensor disconnected, am I looking for 12v?
I think it might be difficult to do because its an intermittent fault. Can I log the heater circuit voltage within Vag-Com? I think that would be the most conclusive way, as you can feel the car struggle just before the CEL comes on - a log would show the dip in voltage when the problem arises.
There isn't any danger of damaging anything with running the engine with the o2 sensor disconnected is there?
I don't have details on the BBY engine, but...
The sensor heater will get 12V and it will probably be pulsed on and off. Take a look at what you see in Measuring Blocks, group 040. It should have the heater status (On or Off) and a calculated resistance:
http://www.ross-tech.com/vag-com/m_blocks/030-049.html
There shouldn't be any danger in running the engine at idle for short periods with the oxygen sensor disconnected. However, I would not advise and hour-long full-throttle runs down the autobahn that way..:-)
-Uwe-
-Uwe-
I have a similar problem on a Skoda Fabia....
http://www.briskoda.net/forums/fabia/fabia-oxygen-sensor-problem/67259/
Looking at group 040, if the field for the resistance is left blank, how should that be interpreted? There is a value for B1S2, but not for B1S1.
Br,
MathiasS
Check the AGR valve and see if there are metal chips in it.
EGR?
Yep, EGR (AGR is the German term).
-Uwe-
I've looked at group 040 - nothing, because its a 1 bank system (i think) - so I should have looked at 041; I'll have to try again tomorrow.
The fault recurred this morning too - same fault codes logged;
Together with the same spurious HVAC codes;
- which has me baffled.......
Sounds like you need a pre cat lambda probe and try resetting the A/C flap motors in basic settings. (procedure is on here).
Got one,
It wont have an effect, it has nothing to do with them. However if the fault isnt sorted with the flap motors as soon as you cycle the ignition the problem will come back.
codes cleared - ignition cycled - autoscan = no codes found :confused:
The two sets of faults seem to happen together.
Cant see why, the systems arent connected in that way. But either way both fault codes are common in thier own right and easy to sort out.
I managed to do a very short log of block 041 plus a couple of others.
Started off with engine off, started engine and idled for a couple of minutes. Resistance of pre cat sensor seems a bit strange (resistance jumps up then comes back down, and its a lot different to the post cat sensor). Any comments?? Does pre-cat lambda probe look like it's defective?
Bigad
Lambda log.zip
