How do i create a list of files and their location?
We have lots of drawings on our server, in various locations. WHilst many people can find them quickly, some that dont access them regularly spend ages looking for them.
How can I create a list of file names and their location?
Woul dbe handy if I could import this to excel or similar to sort alphebetically.
Would also be nice to put the file type in there too (*.dwg or *.pdf)
I gues it all depends if your staff all us the same drive letters.
if they all use the same drive letters you could goto a command prompt on a PC and type "dir *.pdf /s >pdf.txt" from the root of the drive letter. this will create a txt file with all pdf files found on that drive letter and their location. to change it to search for dwg change the command to "dir *.dwg /s >dwg.txt" you can change the text file to be any file name you like and you can also save it to a different file share.
This text file can be imported into excel in a matter of minutes.
Thanks, Matt.
Everyone uses "Z" as the root folder for the drawing locations.
Thats nearly what I'm after:
Directory of Z:\customer folder\MG-Rover
02/11/2004 17:55 44,747 TA750-M18.dwg
02/11/2004 17:34 45,179 WPN-C-B-ELK.dwg
2 File(s) 89,926 bytes
Except I'd like that to be in the format:
Filename1 Location
Filename2 Location
Rather than:
Location
Filename1
Filename2
Thanks, Matt.
the above should work fine then. any probs let me know
Matt - see my edited post above ;)
Thanks, Matt.
Filename1 Location
Filename2 Location
Rather than:
Location
Filename1
Filename2
dir /s /b
may be a bit closer to what you want....
sorry Goochie, missed your edit. looks like sdenny has it spot on..
