Ipod Connection
Sorry if this has come up before, i've had a search but couldn't find the answer i'm looking for.
I'm a bit thick when it comes to electrical gubbins so what i'm going to ask will probably be really obvious, but.........
I have a 2007 Octy with the Aux socket in the jumbo box, does an Ipod just plug straight in to that jack socket or do i need to buy something else?
I haven't got my Ipod yet so i don't know what the connections are like.
yeah just use the 3.5mm jack socket on the ipod. This will not give you control of the ipod via the head unit though. Just audio out.
:thumbup:
If you get a Line Out adaptor cable that connects to the bottom of the iPod you will get a much better sound.
  • 4 months later...
I have just bought myself a nice new ipod to go with my nice new car. Does anyone know where I can get a line out cable that plugs into the docking connection at the bottom of the ipod. I have been looking everywhere with no luck. I envisage a short length of cable with a 3.5mm headphone socket on one end and docking connector on the other. Apparently you get better sound compared to using the headphone socket (cable a 3.5mm headphone plug on each end). If anyone is using one of these cables does it really give better sound?
Im unsure if the above work on the mk2 octavia audio setup.
The first ebay one won't.
Cheers for the replies. I have a vrs so have the aux connection in the arm rest so really looking for a cable that will plug into this. I have been told that the line out feed from the docking connector is best but can not seem to find one.
Cheers Stu the second one was what I was looking for. I had tried searching under line out and dockin connector but had not thought about using ipod base.
Having just picked up my new Octy today :D I have been looking for a similar connector.
In addition to the items already mentioned found this: SendStation PocketDock USB and Audio Line Out MP3 Additions
As well as line out connection & audio cables it also enables standard USB cable to be used to synch / charge.
Guys - trying not to hijack the thread but it doesnt warrant a new one - when you connect the ipod to the car's aux socket; can you control the ipod on the cars stereo (im presuming and hoping yes?) or does the playlist just straight through unless you skip tracks on the ipod itself?
Many thanks and great info on cable options. :)
Lee
IIRC Skoda now offer an Ipod connector in the jumbo box.
Not sure if its as well as or instead of the 3.5 jack.
...when you connect the ipod to the car's aux socket; can you control the ipod on the cars stereo (im presuming and hoping yes?)
nope, fraid not, you can only control the ipod from the car radio or steering wheel when you connect via the CD-changer
...or does the playlist just straight through unless you skip tracks on the ipod itself?
Yup
I went via the dension cable/cd-changer route as i didnt have the stream mp3 so no AUX (but I later bought the MFD2).
