Fabia Vrs clutch pedal
06 Fabia Vrs,as you lift the clutch pedal whilst on the move there is an audible crack/click noise.which is also felt through the pedal Nothing when at a standstill. The pedal assy has slight lateral play--nothing much tho.
Any ideas?
Answers on a postcard please :confused:
I had this issue with my clutch pedal, it went to the dealers twice and they lubricated the clutch but still creaked. Then i traced the creek to part of the underside of the steering column, i tightened two screws and the creek was gone.
I think its two pieces of plastic in the dash rubbing, not sure why this happened when using the clutch though
I have the same issue. go to the dealers. I have yet to go after 4 months of creaking.
it won't go away it gets worse in the cold
