Your input required, direction needed.
Hi All. quick recap, i asked some questions about my dash lights flicking on and of really fast, this was the Ind, battery and <1>.
right, start car, set off ( all fine ) get abot 5 mins downd road and lights start flashing but now get a steady beep, beep ( around 1-2 sec apart ) and this goeas on for abot 10-15 mins and suddenly stops beeping and flashing, the longer i drive the less it does it, around the time the car is at operating temp it just does it the odd time, 1 beep or flas of said lights on dash, now i read the info that the <1> is only for when towing.......i have niticed that if i go over a big dip in road it does beep and flash, strange ??????.
Gonna check all earth cables, check wires under dash but i really dont have a clue as to why it should beep and flash by going over a bump in the road ????
any ideas, pointers, owt really cos i have 2 days off Thursday/Friday so gonna do some checking, really frustrating me now.
Oh 1 other thing, when i turn thie ignition on the little steering wheel stays on untill i start car then goes off, is this correct or should it go off before starting engine.
the car is great, runs fab ( using miller diesel plus ) its just this anoying beep n flash, it has a Serpico ND5 alarm but dont think this will cause said lights flashing. wonder if Skoda them selves have heard of this, anyone got a number so i can ring and check....
Spevie, very frustrated at times........
Pretty sure this one is normal :thumbup:
Its when the steering wheel type light stays on after you've started the car that you need to start worrying! I'm just wondering , have you looked under the back of your car to see if there is any evidence of a towbar having been fitted in the past?
I get the following when ignition is on, and they only clear after starting the engine:
steering wheel warning
EPC
Battery
Gearbox
Parking
Well i checked mine again and all light up then left with steering wheel, battery and handbrake light, all go off when started.
I spoke to skoda uk and they tell me it seems like an electrical fault ( no sh#t sherlock ) so i have to take in to let them see.
Got new battery and guess wot....still the same ? thing is that with engine off and key out, when i open the door i get the indicator lights(dash only) and the <1> flashing about 5 times but no beep, keeps doing it every time.
open door get flashes, close door get flashes.......cant be related to the interior light....dunno, frustrated and getting miffed off.......
spevie
