cambelt and waterpump.?
As Sarah says; The only way I can see a
I've just bought the parts I need for about
If your doing a 1.8T you really need to be changing the hydaulic damper unit that sits under the tensioner. These over time leak and go weak, you then loose the belt tensioner. Make sure you are quoted for one of these as the unit itself is
My car only has 33k on it so I'm hoping the tensioner is okay. I'll ask the garage to check it out while they are in there.
iep
Had mine done, they said the Vbelt tensioner needed replacing as it was wearing into the cambelt cover.
