02 oxygen lambda sensor
Hi Everyone
Does anyone know where i can get a 5 wire lambda sensor from the one befpre the cat?
also just replaced the EGR valve because it was saying (EGR flow insufficent )
when i have replaced its still coming up with the same problem do i need to reset the egr valve if so how
pt
Main Dealer
German Swedish & French
Euro Carparts
Motor Factor
Thats just a few to be going on with.
cheers mate
What engine is it?
If its a 1.4 16v I'd suspect there isnt anything wrong with the EGR valve and its the EGR port under the throttle body is blocked with carbon and thus limiting flow.
What engine is it?
if there is a block in the egr port could this be why i have a problem with the 5 wire oxygen sensor just under the egr valve or could the sensor just be broken
