Fuel gauge, if full tank then ?
Filled up this morning to the brim ( with millers plus added as well ) but my fuel gauge needle sits just under the last white block on right, i seem to remember that if you have a full tank it should be as far as it can go, end of the last white block.
Where is the sender unit ( gonna check it out ) to see if any oddballs with it....
spevie
Can we create Spevie his own section on the site?
sender units under the rear seat
Thanks Lummox, i could do with at the moment.
spevie
You can actually adapt the gauge a couple of litres past min and max, but it might be worth popping the sender out and manually moving it to check it.
Ross
