Oil warning light!!
Help,
I've got a 51 plate Occi vrs, I was driving home from work this morning and the oil waring light flashed on and beeped :( . It came on for a few seconds and then went off, this happened about 3 times, any ideas what it could be??
Have you checked your oil level??
Sorry, I forgot to say that I have checked the oil level and that seemed fine
Oil pressure?
I'd get the codes read by a dealer or VAG COM equipped person.
Red light i'm guessing rather than a yellow one.
Yup its a red one!
Sounds like oil pressure, but if it's happening on bumps rather than, say empty roundabouts, I'd suspect the connection rather than the sender as a first problem.
I had the car checked out at the local Skoda garage, turned out that the oil pump strainer was full of muck, causing the pump to pack up! I now fin myself £550 lighter off!!
That's a first IME.
