Fabia - Handbrake warning Light at Half Brightness - Help Please.
Hi all, as the title -
Handbrake Warning Light at Half Brightness, even with ignition key out.
Goes to full brightness when handbrake pulled up with ignition on.
Wondered if anyone has had this problem.
Thanks in advance
Algi :)
Have you got LED bulbs fitted?
Or is it a brake fluid level warning?
Stu,
Yes, LED Dash.
Algi
Sorry I meant LED brake lights.
Have you checked the fluid level?
the lupo's do that when the rear wheel abs sensors get clogged up with crud!! not sure about the fabia tho.....
i would also suggest checking the fluid level
