Wheel offset & widths
Iam now wanting a new set of wheels for my Fabia VRs, and after searching endless pages from here iam settled on going for 17" again.
My only problem is now
If i went for a 215/40/R17 tyre on a 7" wide wheel, What offset would i need??
I know ita 35-40 but which is 100% right??
ALSO
If i went for the same 215/40/r17 tyre on 7.5" wide wheel, What offset would i need??
one more
again with the 215/40/r17 tyre on a 8"(tyre will the streched I think(giving a different look) What offset would i need??
Ive been on the offset calculator etc but from the standard 6.5 inch to the 7.5inch wheel it means an extra 25mm well an extra 12.5mm in to the inner and then the same to the outer of the wheel arch. Just sounds a lot.
Thanks in advance
Steve
If it helps, my rear setup on a 16" wheel is:
8" Rim
ET27
215/40/16 stretched
The wheel does stick out a bit, but with the stretched tyre, all the tread is well under the arch.
I'm pretty sure this wouldn't look cool on the front though.
Allrate steve hows it going mate?
ill have a look in the rimstock book at work this afternoon, its like a bible of wheels and has every combination of tyre and wheel combination offset etc for each wheel width.
Will post back when i find out.
john
I would be interested in a 2001 Fabia SDI classic setup, looking at finding some wheels for that but not sure which Audi/Vw/Skoda will fit....
spevie
john
Not bad, iam just sick of toss pot alloy wheel companys telling me 19" wheels will fit on my fabia. Hopefully this tread shall shed some REAL life answers about offsets etc, Then all being well i shall have them on by the end of the month :D
8" Rim
ET27
215/40/16 stretched
Sounds awesome. Is your car lowered?? What are you running at the front?? and of course Any pictures??
Cheers again
Steve
hi mate,
had a look today.
on a 17 x 7" wide rim it suggests an offset of 38 with a 205/40 r17 tyre
on a 17 X 7.5" wide rim it says an offset of 37 with a 205/40 r17 tyre
on a 18 x 7" wide it says an offset of 38 with a 215/35 r17 tyre.
If it were mine i would stick to a max 17 inch rim, i know youve already got 215/40r17 so i would put that size on a 17x 7.5 wide with a 37 offset.
Would look nice on 18's but with a 35 profile tyre i think the ride would be too jarring.
Come down to wake ill run some wheels outside to match up to the car if you want?
_________
john
I might just do that, depends on tomro might end up with some 17 x 7" wheels 2morow. dont think the wheels i want come in 7.5 i shall see though.
Ill pm you or give you a buzz depending on what happens.
Cheers everyone
Steve
no problems :thumbup:
Cheers again
Steve
Hi
Yeah, it's as low as the H&R Coilovers will go :)
Fronts are around about the same ET but are 6" Wide with 195/45/16's.
Photos in the Fabia Alloy Wheel thread, and also the Ultimate Dubs 2006 Photo thread :)
ok Would 17 x 7.5 ET38 with 215/40/R17 tyres be ok thats 12.5mm bigger on inner and outter on the wheel arch's?? carnt get the wheels i want in a et37. They come in ET35,ET38 and ET40 i think?
