Skoda Fabia SDI
Basically a nice car, and I'll buy another. But its taken ages to sort out little problems. One problem that can't be sorted without a new car is the lack of air con, now standard - the car gets stifling without it, dont understand why (does anyone know why?). Anyway heres the benefit of my experience:
1. Older ones will need new improved anti roll bar bushes to stop front suspension knocks
2. The water pump has plastic bits which fail - doesnt damage the engine apparently but you'll know because the heater won't work.
3. Door seals will need replaced if you notice damp carpets
4. If/when the dashboard starts driving you mad with a creaking noise, stuff something firmly between the middle of the dash and the windscreen
5. If the brake lights keep fusing try getting a new brake light switch fitted
6. Screeching wiper blades - fit Valeo Silencio blades
7. Power steering might get tempremental. Sometimes sorts itself out - if not you need a new sensor.
8. The rear washer tube always pulls apart
Welcome.
Other suggestion for (6) would be to clean the windscreen and blades. I'm like that; always try the cheap fix first!
  • 8 months later...
Sorry i didnt reply to you earlier - didnt notice it until today. In the event I got new blades - called Valeo Silencio - and they work much better. Thanks again.
