Liverpool Victoria new online quote system
just checked, elephant with 11-25% power increase will be
So what would it be for a 53% increase in bhp for a Jabba's 4X4? :(
11-25% ?
Better check those figures i think ;)
Unless you're only hoping for 225Bhp from Jabba :D
thats approx what you get anyway is it not?
233 ;)
Which i admit is only slightly over the 25% but you know how insurance companies are.
yea know what you mean, averag is said to be 218-230. i would be happy with 225 from jabba, afterall the wont dyno the car i doubt
Well, in that case theres nothing to stop you calling Jabba then, is there ?? :D
still need the cash tho! cant wait to get it jabba'd,
now, boost controller or no boost controller
Easy. Boost controller.
Why ?
See Jabba's site here for the answer.
Boost controller is cracking! :thumbup:
Hardly ever use it on max...usually around 3/4....but when the weathers cold enough crank it right over ;):D ......it's going to be particularly useful if Summer is as hot as last year. Because of the temp boost can't be held as well so you urn it down to suit and car will perform better.
Also if you're so inclined set it to minimum when going in for servicing.......had a go at running on minimum for all of 5 minutes ;) .....I'd forgotten what a standard RS was like......remap makes one hell of a difference.
Other benefits of fitting the boost controller is that it allows Jabba to play around with the overboost and torque limiter limits.....basically more boost....they wouldn't otherwise do this but seeing as you have control they're happy for do to this.
Fitting is excellent and very discrete.......well worth the money...
cool, where on the dash di u get it fitted?
Between the steering column and the headlight level adjusters...nearer to the steering column though.
You can remove the control nob and replace it with a jack plug which has a resistor in it to set it for minimum....just for those servicing moments. ;)
Nice neat job....well recommended. :thumbup:
cool, cheers for the info
