Trunk light
I have a problem with the light in my skoda fabia trunk
When i open my trunk the light doesn't work
then i saw that the light has a + but doesn't have a - (i tried to connect the - with the car tin and the light works)
Why doesn't the light work when i open my trunk?
Where is the switch that makes the contact when i open the trunk?
btw: sry. on my bad english
anyone?
whats a trunk ?
whats a trunk ?
A Boot
As i've only got a humble Classic, which (AFAIK,DOESENT HAVE ONE ) can't tell you where the switch is - would suggest that it is somewhere in the area under the tailgate .Usual auto idea is to wire +12volts to lamp, and switch supplies - (or ground) - as you say -putting other end of light to chassis (tin) lights lamp, i would look for switch and investigate poor contact in switch.
yea i must find switch, i can`t see it.
If anyone have fabia to take photo of his position
The switch is in the catch on the tailgate. I would think either your screen wash is or has been leaking and has corroded the connections onto the switch.
thx i will see catch
weeee i found it now it works thx one more time
Glad to help, what was the fault exactly, may help other members.
corroded connections :)
