Oil pressure gauge
where do i plum it in to the octy vrs?
i have done a search and it didnt actually come up with a location or a how to!!!
some one must know.
thanks in advance
Usually with a t piece on the oil pressure switch.
and where is the oil pressure switch?
I know this is in the octy forum, but would this apply to the pd130 as well, and if so, where is this switch located exactly. i tried looking elsewhere at some source info I have and couldn't find the location.
Same place near enough on the oil filter housing at the front of the engine.
Demon Tweaks sell T-pieces designed for this purpose in a variety of sizes so might be worth a look if you get stuck... I would like an oil temperature gauge and have also been looking into where to plum it in.
I got a special adaptor for mine which is designed for the 1.8t engine,you undo the factory oil pressure switch on the oil filter housing and screw in the adaptor which has about a 1ft length of braided hose with a brass tee piece so you can re-fit the existing pressure switch and your aftermarket one then secure it in the engine bay,my oil temp switch also connected into the oil filter housing,there's a blank plug fitted which can be removed with an allen key
Where did you get the asaptof from?
