fitting abd tip
well going to have a go at this tommorow morning weather permitting . is it an easy job or difficult one ,anybody fitted one of these before and fancies lending a hand or guidance . then feel free to turn up i wont moan:D seriously though any advice much appreciated cheers in advance
Phil (piv34uk) did mine a long time ago and it was a pain to do it from above the engine. If you're able to get underneath the car then you got it much easier.
Mike fitted mine this morning :)
mike at impossible does it from the top.
to be honest, looking at the location its going to be more awkward than any hting else as you wont beable to see what your doing due to your hands and pipe work being in the way.
just do it early in the morning, give your self some time to loose your temper with it, throw it across the road, retrieve it and then calm down enough to give it another go.
take it easy
Quiet easy to do from the top, but you need small arms as you need to reach down the side of the engine. Its much easier to get at after removing the airbox.
This job is better done from the top of the engine.
Be prepared to lose some skin from knuckles.
I spent lots of time both under and over the engine bay. It was a bugger to get onto the turbo.
If I'd had a mate to help it would have been much easier!
