1.4 how can I tell if it is a PD engine
I have a 1.4 TDI bought in Italy under the model name Urban with 51 kW of power. Is this a PD engine and what is the difference between this unit and the 59 kW one.
Jeff
It sounds like a PD to me. Can you post a pic of the engine without the engine cover on? Should be able to tell then. :)
They're all PD's aren't they? Never heard of a 1.4 low pressure TDi.....
Yes its a PD unit, just with 70ps.
Jeff
It would be PD.
The kW power is the difference from what I can see, yours will be slightly less power than the other one.
There are a few variants of the 1.4 PD engine, but all the recent VAG 1.4 diesels are PD. :)
All Fabia diesel engines are PD (aside from the SDi).
