Vrs Standard Springs
Hello All Can Some Tell Me is it 100% possible to fit Standard VRS Springs on a Standard 1.4 non Vrs Fabia.
and what are the effects ride height safety aspect shoicks ect ect
thankyou all
Nope is the simple answer, incorrect spring weights for your engine and transmission.
Quite right; I like a dummy went and did it (without fully researching the subject first) and found that the front ride height INCREASED by about 20mm, whilst the back went down 15mm !!!!
The vRS springs are set up for the heavier TDI engine hence the above result.
If you want to change springs, go for eibachs.
If you want to improve the handling etc; go for the JabbaSport Rear anti-roll bar. Cheaper than changing springs and or shock absorbers and far more effective.
Thanks For The Help Chaps
can you tell me the part number for the eibach springs as looking on there web site it list notch back
whatever that means
i have a standard 1.4 hatch 05 year.................thanks kindly
Hi there,
Yours will be the Fabia (6Y2) {notchback is the saloon} and for the 1.4 engine you need Pro-Kit part no E7910 140
Hi all, just in case anybody's interested, I have a set of standard vRS springs I'm about to throw away... Obviously as above they're no good for a lower model in the range but I'm sure somebody can make use of them. Free to a good home. (I hope this doesn't get deleted - I'm not selling them, I'm giving them away!) I'm in South Wales.
How much is the Eibach kit for the 1.4 8v?
