Rear jet reconnect pipe?
Hi,
When I call for the rear jet to spray on the rear window, I just get a load of water spewing out of the bottom of the car.
Front jet works fine.
I think that it's a disconnected pipe?
Can anyone guide me as to how to reconnect this?
Open the bonnet, get someone to sit in the car an operate the rear screen washer. Look down between the engine and the bulkhead on the passenger side and you should see where the pipe has disconected at the connector.
It just snaps back together again ! :)
Spot on description - ditto!
Thanks, worked a treat, sorted in 5 mins.
Now need to find a way to get rid of my squeaky brakes!
Do they squeak all the time? or just at low/parking speed & light application?
When were your pads/shoes last changed? How many miles have you done?
1st suggestion; give them a GOOD workout i.e. several hard applications from 60 - 70mph. Often a bit of a squeak is just a build up of dust & rust on brakes that never get properly used; this should clean them up.
