Engine coolant warning light
When I start my Mk 1 octy vrs up on a very cold morning (frost on windscreen and indicated temperature of below 1oC) after about 20 seconds there is a beep and the engine coolant light on the dash comes on. If I stop the engine and restart the light will go out and normally stays off. Occassionally I have to switch the engine on and off a couple of times before it does not come on again. Does anyone else have this problem? Does anyone know what is causing it? I would be grateful for any insights.
Hi Mate
Yes it is a common fault of the expansion tank
There is a sensor on the tank that gets clogged up and goes faulty
Some have said if you clean it up it will go or top up the coolant just above the max it will go out
But they are very inexpensive (approx £10.00 ish ) and dont take long to do
Just check the level before you go doing anything like this though
If you do ANY work on the coolant , check the engine is cold before you start it
Sarah
Cheers for the quick reply Sarah.
My male ego has not been too dented by being told the answer by a girl !!!!!!!!;) :eek:
lol
lol, Sarah is the Lady of Briskoda.
