annoying squeak from sunroof controls
i have just purchased my car, fantastic with the exception of a squeak comming from the sunroof controls. i am intending to dismantle and de-ratle however if you push the round switch up (into the roof) it will move about 3 cms until it nearly disapeears, is this normal as the rotary switch works fine, if not i expect this may be the problem. Any one else had a rattle in this area?:confused:
No idea, beyond that the vertical movement in the control switch sounds far from normal. Does the surround and courtesy/maplight setup move significantly too?
no, i will take it all apart and look for the annoying squeaking bit!
