Crazy mirrors
My door mirrors have suddenly had a change in the way they operate.
Normally, the "L" operates the left hand mirror and the "R" operates the right hand one.
All of a sudden, the "L" operates the left hand one, but the "R" operates both at the same time!!
Anyone else got this???
They have to be reset.
Somehow.
Mine did this,and I got the child to fix them.
Do you want to borrow her.
I can deliver.
i think disconnecting the battery will reset them , but don't quote me on this
Sorry guys, I think this is normal :P
Mine does it too, if you look on your furby, does it say "L" and "R & L" and possibly the heater symbol too?
If so adjust the R & L first to set the right hand mirror. Then, once done do the left one by selecting L.
Sorted :thumbup:
I thought it was a normal function, designed so that you don't have to adjust both. Not sure if mine does it but seen it on many cars.
Mine does the same thing - dealer confirmed it was normal...
Hmmmmmm.....strange......some do, some don't!
It's not a real problem, because as Pembo says, I just adjust both, and then re-adjust the LHS one.
Just thougt it was a bit weird.
Tis normal, its in the owners manual and covered on here loads
Yes but the chap original said that his worked like mine do..... L for left mirror & R for right mirror.... No adjustment of both..... Mine works like this and i have no way of adjusting both mirrors at once. Wasn't it the pre facelift cars that adjusted the mirrors both at once???
I suspect they need a reset as mentioned above.
Dave.
