engine power
What power can you get out of the vrs engine with out spending sill money i:e 2k?
buy and fit a 225 engine from either a TT or a leon cupra R. then remap it later for around 260bhp.
Hi mate a remap panel filter and forge recirc valve or Dump valve if you prefer will get you around the 225 to 230 bhp mark for around
if you don't fancy that then get a simple remap, better discs/pads/fluid and get on a driving course to improve yourself :)
I like keep same engine revo s+s turbo back exhaust 230- 240 bhp would be nice for about 1200 ish?
go look on ATP turbo.com you'll get alot for 2k dont bother with a 225,upgrade the turbo,clutch DV and stoppers and map it......should see it min around 290 thats from seeing a Octy RS done that way on rollers after i helped do the work,oh and if u can get the piping for a intercooler get the cooler it self for a TDi a big one.A merc sprinter's cooler does it......just a few ideas for u,i seen them all done so i know they work more r less,not sure how the intercooler worked out in the end though.
you will not do that much work for 2k, i know this for a fact :)
the only possible way to get all that for 2k is to buy 2nd hand and do all the fitting yourself but your gonna need to to know what your doing and have all the tools and ramps etc at the garage your doing it.
the cheapest ATP eliminator kit is $1400
3" inlet kit(required for ~300bhp) $259
delivery $175
so after import duty its around
