vRS steering wheel
Does any body know if the centre cover on the steering wheel can be removed and replaced easily?
I had the airbag replaced after a prang but I'm not sure they've assembled it the way it should be because the cover is slightly loose at the the 6 o'clock position - I remember the whole thing being pretty solid before.
sounds like the airbag has not been fitted correctly , it could be in a dangerously unsafe condition , i.e. if you have another prang , it may not inflate in the correct direction causing you injury
i'd get it checked out A.S.A.P. either by a dealer or the bodyshop who repaired your car
Sounds a bit dangerous.
