Crackling
Anybody elses Vrs crackle when you turn the ignition?. Going in for a service tomorrow so I thought I would ask so I can get them to sort it out. Sounds like it's coming from the front speakers.
I presume you're not refering to the fuel pump? Just before you start the car the fuel system is primed and you will often hear a whoosh noise!
I used to hear a 'squidgy' noise on mine - perfectly normal.
No it's defintely something to do with the radio. If I turn of the radio off on an evening and start the car in the morning it does'nt sound as much. Weird!. I know the sound of the fuel pump which is a lot more mechanical.
Squelching from the pump priming is my bet.
You can set the volume of the radio on start up via the convoluted menu set up.
going to say the same thing hahaha
i personally think it sounds like a wet fart lol
i get this too. a definite crackling noise immediately after turn ing the ignition key and before the engine turns over. :confused:.
04 fabia vrs.
