Never noticed this
Currently sitting in 13th place and not moving very fast nowadays
but i never noticed how many WU i have finnished
I have compleated well over 3x as many work units as BPM or Mannyo
or nearly as many WU as the top 6 put together
:( :( :( i want better value for money with my work units
If you go to "Configure" and then click the "Connection" tab, you can tick a box that allows you to download bigger work assignments - maybe that will help???
James
Check the FAH log, the only way to get that many WU's with a low score is with lots of units failing. Checking just now and you now have 162855 points with 21024 WU's. Thats nearly another 1000 WUs with no points, so something is very wrong. A common cause of early unit ends is if your CPU is overclocked.
:( havent got any overclocked PC's
i thought this was down to the GPU pc i have folding 24/7
as i didnt think you got as many points for them it does seem to finnish WU very fast
ill have to do some investigating :(
If you are using the GPU client with your ATI card, it seems very fussy as to the version of catalyst drivers you have installed. Version 6.5 is aparently the most stable with most later ones having problems.
