HELP! door carrier
Help! My window has dropped and its raining! I've stripped it all apart from the door carrier which is stuck. I believe it is the regulator but how do I get it out?
I've searched the forums but ther is no mention of this tricky little bit. Thanks in advance, James
James
PM me an email address.
The regulator comes out with the carrier, its the same part.
You dont need to remove the lock if you poke out the plastic rivets (they aint needed). Have you disconnected the window?
What plastic rivets are they? Yes, took the window out
Towards the back in the top corner.
Not sure what you mean. The three funny plastic things half way down the carrier?
Those three plastic rivets.
