Octy vrs gear ratios?
Going to have a power run done on my octavia vrs using rotatest equipment which bolts on to the hubs and is more accurate than a normal rolling road.But for the readings to be accurate operator requires gear ratios/final drive ratio, have checked haynes manual but cant find , can anybody oblige?
My best suggestion is to find out which gear(s) the operator wants to work in, and back-calculate the overall gear ratio from observation of road and engine speed in that gear. In any event he only wants these data in order to calculate a nominal flywheel figure from the wheel figures he's actually measuring.
Gear ratios/mph per 000 for RS as follows:
1st = 3.3/6.2
2nd = 1.94/10.5
3rd = 1.31/15.6
4th = 1.03/19.8
5th = 0.84/24.3
Final drive ratio is 3.647
Therefore max speed at 7k is
1st = 43
2nd = 74
3rd = 109
4th = 139
5th = 170.1
4x4
1st----3.780--- 4.8
2nd---2.060--- 8.87
3rd---1.360--- 13.5
4th---1.030--- 17.8
5th---0.840--- 21.8
Final drive: 3.940
Max mph @ 6k
1st = 28.8
2nd = 53.2
3rd = 79.2
4th = 106.8
5th = 130.8
Thanks for that
no worries
Don't suppose you've got TDi 110 numbers to go with those, have you?
J
