Replacing rear light cluster...
Reversed into a telegraph pole, oops (haven't done that for 9 years) :o
So need a new light cluster on the Fabia, I take it they are easy to fit but any hints?
Also need a drop of scratch-X for the bumper. Look out for those telegraph poles everyone, they're horrid :o
Taken from: Fabia-vrs.com - Home Page
To remove the bumper you'll need to remove the rear lenses from the car. Pull back the carpet inside the boot and unplug the wiring to each lens, then using an 8mm socket or spanner remove the 4 nuts that hold each lens in place.
not on topic I know (sorry) but are there any smoked aftermarket rear lights for the fabia?
apart from those god awful lexus examples?
Are you after a standard or facelift rear cluster?
Steve
You've actually reversed into a telegraph pole more than once?
