312mm conversion - done
I've finally done the brake conversion and now have done about 400 miles and under normal use I don't notice much difference but if you need to stamp on the pedal they are quite a lot more powerful so it seems worthwhile.
I used the Britax brake box kit for a TT off Ebay and that all was ok - one side took about 3 hours (no problem just kept raining:mad: ), the other about 1/2 hour:) .
Thanks to Mluton and Lummox for pictures and DGW for torque settings, also Gary at Fenland Breakers was helpful/knowledgeable about bits and what I was doing.
I did also get the splash/stone guards off a TT but they do not fit as not enough mounting bolts.
Good work mate
Well done. Never really done the conversion for stopping power just for pedal feel.
As I say it doesn't really feel any different till you try hard, then its def. better. Pads were worn down and discs had done 41k so just seemed a good time - and was worth it.
Might be down to the pads or the fact my std brakes where fooked. :rofl:
swmbo noticed the firrence striaght away. :thumbup:
trust me m8.. excellent mod if you need to stop quick.. :thumbup: especially if u are remapped.. :D
Brake shields aren't mandatory, and don't really do much other than keep some water off the inside of the discs.
i did the 312mm converstion a couple of weeks ago with a mate, and the brakes have never felt soo good. Their way better than the standard ones and you barely have to press the pedal now.
