My fault codes!
Thanks to Fatty5000 for very kindly scanning my car whilst ooop north on holliday!
Chassis Type: 1U - Skoda Octavia
Scan: 01,02,03,08,15,17,19,35,46,56 Address 01
Controller: 06A 906 032 HN Component: 1.8L R4/5VT G 0001
Coding: 11500 Shop #: WSC 31480 TMBER21UX28558967
SKZ7Z0A1205827 2 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - - Intermittent Readiness: 0000 0000 Address 03 -------------------------------------------------------
Controller: 1C0 907 379 E Component: ESP
FRONT MK60 0104 Coding: 0019970 Shop #: WSC 31480
No fault code found. Address 08
Controller: 1U1 907 044 A Component: CLIMATRONIC C 2.0.0
Coding: 11000 Shop #: WSC 31480
Skipping Address 15-Airbags Address 17
Controller: 1U0 920 911 C Component: KOMBI+WEGFAHRSP VDO V04
Coding: 21412 Shop #: WSC 20028 TMBER21UX28558967 SKZ7Z0A1205827 No fault code found. Address 19
Controller: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 31480 No fault code found. Address 46
Controller: 1C0 959 799 B Component: 3Y Komfortger
Voltage low just means the battery has been disconnected or has got flat.
Ah thanks! That would make sense, I had it out the other week
