What part is this?
the little pocket, i think it looks much neater than the one that goes below.
That is the standard tray which goes below the HU isn't it? haven't the two just been swapped around?
I agree with Jase. :thumbup:
Chris
Dont think so.
The regular tray is DIN sized, the one above is larger as it meets the switch gear at the top where you would normally have the fascia adapter.
Could well be a Skoda part
6Y0 857 925 47H - shelf/stowage compartment upper onyx
how did you get that part number, does anyone else think it looks smarter?
I think it looks alot better that the standard lower tray, aftermarket headunit and the adapter fascia yes.
Part number was from my ETKA parts system.
Yep, the tray is definitely not the normal one from below the headunit - its bigger.
I agree, looks much nicer than the alternative. I also agree with Ross's part number there - probably isn't too dear either.
Nice find!!! :thumbup:
If you have the fascia adapter already, can't you just swap the tray and H/U around?
I dont think it will work as the tray has the locating ridge at the to pof it for the radio.
The tray is curved from top to bottom, so no, it wont fit right.
