Skoda Octavia II 1.9 tdi VAG-COM error 18104
Hello!
Today I checked my car and I got following error:
18104 - Powertrain Data Bus: Implausible Message from Steering Column Controller
P1696 - 000 - - - Intermittent
Freeze Frame:
RPM: 1386 /min
Torque: 26.8 Nm
Speed: 22.0 km/h
Load: 9.0 %
Voltage: 14.14 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 1.0
Readiness: 0 0 0 0 0
What this error mean?
Is maybe some connection between cruise control and this error, because few days ago I tried to turn on cruise control and nothing happend. Then I stopped the car and started it again and then was everithyng OK.
Thank you.
Bye, Borut
Was CC fitted at the factory or have you fitted it and then have enabled it?
CC was original in the car.
I would suggest then that it has one of the batch of defective stalks. Your dealer should fix this under warranty.
I Had The Same Fault Code Along With Fault Code 00895 [ Cruise Control Switch E45 Defective Intermittent]. If You Ask Me, I Think You Need The Cruise Control Stalk Replaced.
Known issue and you are already on the right track, most likely that the stalk is faulty - as Stu already said there was a bunch of improperly designed ones and you dealer should fix it under warranty. ;)
  • 1 year later...
Hi all
I have this fault 18104. i replaced CC stalk, but it does not solved this problem.
You may wanna post a complete scan then.
Hello Theresias!
I am registered VCDS user, from hungary.
Kedd,16,December,2008,08:08:44:54795
Verzi
We can work with the Hungarian version but still need a FULL Auto-Scan because this code does relate to more than just the ECU.
Okay :)
Verzi
Theresias!
Do not have any idea?
regards
Sorry for not replying earlier, been on vacation for a couple of days and then there was of course the other thing people call Christmas... ;)
By going through your scan I found that there is an update for your ECU part number, however I am not sure which version number is current and therefor its questionable if it applies to your case or not. What you could do though is simply try, or at least your dealer could.
Where did you get the stalk you installed? Used or new?
There is another known thing with a software modification in the steering column control module but since your module is rather old it would have to be replaced.
Hi Theresias!
I replaced brand new cc stalk. I call phone to Audi service, and he will refresh steering electronic.
Tahnk you for help!
But!
I searchig 059-907-401-ASB.LBL file. (english or hungary:-)) Have you got?
Donibcsi
