Fitting VW Double DIN MP3 H/U into VRS?
Hi,
I am looking at getting a new head unit which plays MP3s for my Fabia VRS. I want to get a double DIN unit which looks factory to stop being broken into.
I am looking at the VW RCD 200 H/U. Will this fit the Fabia and if so will I need any other parts?
Also are there any other double din head units which will work?
it looks like it will fit in the hole, but I dont know about the connections on the back. If the hu uses standard ISO then there shouldnt be a problem, however if it has a quadlock connectior then I dont think it will connect to the fabia.
if it is quad lock mate i could make up an iso to quad lock connector for beer tokens :thumbup:
_)___
john
Slighty off topic but would you loose the 6 CD changer?
Id watch out as alot of these use CANBUS which im not sure the fabia has
Have been told it uses the quadlock connecter. Is this okay?
